Hot water venting out from overflow
Postby da51dbr0wn » Fri Nov 28, 2008 11:42 am
Every time my thermostat switches off the hot water the system vents hot water out of the vent. The temprature of my hot water is also scalding hot.
Any advice please
da51dbr0wn
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby Steve the gas » Sat Nov 29, 2008 6:38 am
Turn down any HW stat you have eg on boiler and/or cylinder stat.
Then post back pls
Steve the gas
Rank: Site Agent
56%
Postby da51dbr0wn » Sun Nov 30, 2008 9:32 am
Steve,
Thanks for the reply.
I have done as you requested and it is worse, in that it occours more frequently.
da51dbr0wn
Rank: Labourer
50%
Postby htg engineer » Sun Nov 30, 2008 1:20 pm
Type of system ?
Make/model of boiler ?
If it's a gravity HW system - replace boiler stat.
htg
Rank: Project Manager
Postby da51dbr0wn » Tue Dec 02, 2008 7:13 pm
Htg,
The boiler is a Potterton Flamingo 50,
I am assuming it is a gravity fed system, as it is not on a pressurised ring main.
Off to the attic and down to the plumbing suppliers tommorrow for a new thermostat.
Am I right in assuming the following:
Switch of the electricity at the mains,
Switch off the boiler,
Drain down
Replace the part,
Reverse the proceedure.
da51dbr0wn
Rank: Labourer
50%
Postby htg engineer » Thu Dec 04, 2008 5:49 pm
I'm pretty sure it will be a gravity HW system.
So what are you going into the attic for ? immersion maybe ?
- that's not the boiler stat.
Drain system ? not normally necessary to change boiler stat, as the phial will sit in a dry pocket.
htg
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
