how do i make an opening in brick
vw754
by vw754 » Fri Sep 05, 2008 8:42 pm
i want to fit a vent in the frontroom and was wondering how i can cut an opening out without damaging newley plastered walls?
by htg engineer » Sat Sep 06, 2008 7:12 am
What size vent ?
You can get ones very similar to an extractor vent, square covers but the bridge is round - use a core drill, will give a neat, tidy finish.
http://www.toolbaydirect.co.uk/product_ ... hp?id=3862
Don't want to buy or hire tools ? draw around the vent whether square or round, then drill holes all the way around the pencil line using an ordinary masonry drill, then knock out with hammer and chisel, any rough edge will be covered by the vent grille. Time consuming but effective.
htg
screech
by screech » Sat Sep 06, 2008 11:43 pm
just a word of warning as previously said you can fit the circular vent but htg engineer forgot to mention that if you want to use that core drill bit you'll need to buy or hire a core drill, a normal drill will not cope with it.
