How do I remove old central heating thermostat from wall?
Postby Kitty » Tue Nov 27, 2007 9:32 am
Hi there..I have moved into a new house which has had a new boiler and new thermostat control panel fitted. They have left the old thermostat control on the wall in the hall - old school square box style with wheel. I want to remove this completely as it is ugly and not in use and then wall paper over where it was and repaint. I have no idea how to do it!!!!! I've looked behind it and it is still wired up so I don't know what to do next.....can anybody help???
Cheers.
Kitty
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby DONFRAMAC » Tue Nov 27, 2007 12:37 pm
I used to have just such a thermostat, to feed the under-floor heating element. At the time, I wanted this feed of power, to redirect it down, using a terminal-block, to a fused wired outlet to a storage radiator. I then permanently covered the round conduit-box with the proper steel cover-disc and 2 cheese-head machine-screws, from a builder's- merchant's. I then filled over the disc with ordinary poly-filla, and decorated over that.
So, all you need to do is switch off the mains power in the house, and remove the thermostat from its wires, and clamp each of them in a scotch-block terminal connector. Wear rubber gloves if you are nervous. Ensure no wires protrude from the connector-block, and tape it to the back of the conduit-box, and screw a suitably recessed cover-plate onto the box, and plaster etc, as req., at your leasure. Restore power once the cover is in place.
DONFRAMAC
Rank: Ganger
96.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
