HW only works when CH is on
Postby paul_vw » Sun Jan 27, 2008 4:42 pm
Hi, just a little help required here,
when requiring HW, we have to put on the CH, can anyone advise the fault?
the boiler is made by arrow and model says C24
thanks
paul_vw
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby htg engineer » Sun Jan 27, 2008 5:52 pm
Never heard of that make or model of boiler.
What type of boiler is it ? a combi, back boiler etc
Do you have a tank/cylinder ?
Rank: Project Manager
Postby paul_vw » Sun Jan 27, 2008 8:34 pm
Hi, i've lost the plot, its a Alpha CB24-CB28 combi
paul_vw
Rank: Labourer
50%
Postby htg engineer » Sun Jan 27, 2008 9:18 pm
DHW switch / diverter valve fault. Would be best getting a heating engineer in to repair.
If you are competent, as you are not breaking any gas supllies, removing and combustion seals etc you could attempt this yourself.
Read your boiler instructions - it tells you where the diverter valve and DHW switch is, how to remove and replace etc.
Bearing in mind I only know what you've told me, for an accurate diagnosis, get a heating engineer to take a look.
Hope this helps
Postby paul_vw » Sun Jan 27, 2008 10:48 pm
thanx, think i'll take your advise and get engineer in
paul_vw
Rank: Labourer
50%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
