immersion boiler over heating
Postby dstewart » Fri Sep 07, 2007 3:12 pm
everything with cental heating appears to work fine, including heating of water within immersion tank using gas. I therefore presume that thermostat strapped to immersion tank is working fine. However, when i attempt to heat water using electrical switch in kitchen, water is very over heated and immersion tank begins to shake and is quickly turned off BY MYSELF !
Davie
dstewart
Rank: Labourer
Progress to next rank:
75%
Sponsor
Simply Build It
Postby LES COWIE » Fri Sep 07, 2007 9:19 pm
The electric immersion heater has its own built in stat, sounds like this is faulty. Shouldn't be a costly repair. Your boiler should heat up the water a lot quicker and cheaper than the immersion heater, this is generally only used as a stand by if the boiler is faulty
LES COWIE
Rank: Apprentice
47.4%
Postby The Heating Doctor » Fri Sep 07, 2007 11:01 pm
Either the thermostat in your immersion heater is set to high or it is not working at all. The stat will be under the immersion heaters cover.
The Heating Doctor
Rank: Foreman
4.7%
Postby dstewart » Sun Sep 09, 2007 10:22 pm
on checking, my immersion element has hole where thermostat perhaps should be ( I presume removed by previous home owner) I will therefore replace element.
Davie
dstewart
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
