Bought a thermostat for a combi boiler and can't work out how to wire it in. The thermostat is 230v, the instrusctions say 230v input and output, and has terminal connectors for N L SL. The boiler has 2 connections for a thermostat that currently just has a bit of cable connected between them meaning the heating is permanently on unless switched off manually. the voltage between the 2 connectors in the boiler however is only 12v. does this mean that the thermostat is incompatible with the boiler? If not how should it be wired?
rosebery
2021
Post by rosebery »
Fri Dec 04, 2009 7:07 pm
Ollie
It would be a good plan to identify what it is that you a trying to connect to what by reference to manufacturer and model / part number rather than a generic "boiler" and "thermostat".
DEEARR2
160
Post by DEEARR2 »
Fri Dec 04, 2009 8:23 pm
If you have a standard mechanical type thermostat then connect across L & SL. The N connection is there to operate an anticipator that closes the on/off differential by a couple of degrees.
