Motorised CH Valve
Postby rgkl » Sun Dec 28, 2008 5:19 pm
[size=18]The BGMVSP2 has an indicator lever with 2 positions A-B, can I assume this is an indication of open/close is this correct? if so which is which? If the indidcation is between these 2 positions does it mean the valve is jammed or is it a "no power" indication?[/size]
rgkl
Rank: Labourer
Progress to next rank:
75%
Sponsor
Simply Build It
Postby plumbbob » Sun Dec 28, 2008 10:24 pm
When the power is off, the lever will be at one end and the valve will be closed. Pressing the lever towards the opposite position should open the valve and as the lever moves across you will feel a resistance as the motorised gearing spins. When you release the lever, it should slowly return to the original rest position.
If the lever is loose and floppy, or not in a different position it is either jammed or the power is holding the valve open. You can only test the mechanics reliably with the power off.
plumbbob
Rank: Project Manager
Postby rgkl » Mon Dec 29, 2008 10:27 pm
Plumbbob - Thanks for the very useful information. I have exercised the offending valve with the power off and it appears to have recovered and is working OK tonight. So I will keep an eye on it for the time being and will look to replace in the NY. Thanks again for the good info and rapid reply
rgkl
rgkl
Rank: Labourer
75%
Postby radar » Wed Dec 31, 2008 9:05 am
rgkl
for what its worth, I had a similar problem a while back. After operating the valve manually, it worked, for a while! ended up replacing the motor and has been fine ever since.
radar
Rank: Apprentice
5.3%
Postby rgkl » Wed Dec 31, 2008 4:41 pm
Hi Radar, you mention about changing the electric motor, so that's possiblle then, are these normally held as spares in CH retailers, what your saying is I dont have to change the valve just the electric motor?
rgkl
Rank: Labourer
75%
Postby Steve the gas » Wed Dec 31, 2008 5:56 pm
Yes, if thats the problem.
Steve the gas
Rank: Site Agent
56%
Postby nitro23456 » Thu Jan 01, 2009 12:39 pm
Yes change the actuator with the power off.
nitro23456
Rank: Foreman
48.7%
Postby radar » Thu Jan 01, 2009 2:17 pm
yes mate,
was easy and worked for me.
all the best
radar
Rank: Apprentice
5.3%
Postby rgkl » Thu Jan 01, 2009 10:43 pm
Thanks for all your help, much appreciated
rgkl
rgkl
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
