New system: radiators don't heat up! Please help!
Postby cooldoc » Sat Feb 02, 2008 7:03 pm
[b]Our Megaflow system, with a Valiant ecotec boiler, is two years old. A few months ago the pump was replaced because of debris inside the pump. The system was powerflushed with the new pump and radiator valves. Now, out of eleven previously working radiators, only two heat up and are lukewarm.:cry: However, the boiler and water system works perfectly well.
Any suggestions would be gratefully accepted.
Many thanks. [/b]
cooldoc
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby htg engineer » Sun Feb 03, 2008 5:59 pm
Check pump is running, vent pump and radiators.
Let me know if this does anything.
Rank: Project Manager
Postby roger196 » Sun Feb 03, 2008 7:33 pm
Is the new pump actualy working. If you lightly hold flow pipe from boiler, does it feel hot. Has pump been bled.
Are rad valves open.
Are TRV's on rads stuck.
Have rads been bled.
Has room stat been turned down.
roger196
Rank: Ganger
22.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
