No hot water, CH ok
Postby Pivotal » Sat Jul 07, 2007 8:02 pm
Hi thanks for the replies, I got posted to a different base for the past week so havent had access to either the internet or the problem.
When the stat trips the orange get 190VAC, otherwise the blue gets 240VAC.
Pivotal
Rank: Apprentice
Progress to next rank:
26.3%
Sponsor
Simply Build It
Postby plumbers1 » Sun Jul 08, 2007 8:36 am
GET QUALIFIED EXPERIENCED PLUMBER?HEATING ENGINEER TO DO JOB, THATS BEST ADVICE!
plumbers1
Rank: Tradesman
53.8%
Postby Pivotal » Tue Jul 31, 2007 11:26 am
I would like to thank the people that offered help & advice, I have fixed the problem & hope the solution may help someone in the future.
I went to a diy store to look at the workings of a new valve so I could see what the inside of my valve was doing, that increased my knowledge.
I checked all circuits again & couldnt find a problem, so I went back to the the starting point - low pressure.
I part drained the system via the lowest radiator (decided to take the valve of while I had the chance), then I refilled it SLOWLY, making sure to manually put water through the HW circuit & the CH circuit, until it reached pressure. I bled the radiators & some from the system pipe & left it over night.
Next day switched both circuits on independantly & both worked, but they were both noisy, I bled again & left another day. Now work normally.
I spent just 99p & gained a lot of insight into the workings thanks to the input of others (well not PLUMBERS1) on this DIY forum, I hope I can repay the favor on the various IT & Photographic forums I participate on.
Pete
Pivotal
Rank: Apprentice
26.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
