no hot water pressure from combi boiler
Postby alangjones » Mon Jan 14, 2008 8:05 pm
I have a firebird combi pac oil fired boiler which has a slight problerm with, the radiators are working fine and i have hot water but there is no pressure at the hot water taps I turn them on and all i get is a trickle can any one help many thanks AJ[size=18][/size]
alangjones
Rank: Apprentice
Progress to next rank:
0%
Sponsor
Simply Build It
Postby frogger » Tue Jan 15, 2008 5:45 pm
sounds like the heat exchanger is scaled up. Have you had any dripping hot water taps that have been going for a while?
frogger
Rank: Tradesman
7.7%
Postby alangjones » Fri Jan 18, 2008 12:27 pm
no we have n't got any leakey tap's is there a way of checking the heat exchanger and if it is blocked how do i clean it out
thanks AJ
alangjones
Rank: Apprentice
0%
Postby alangjones » Thu Feb 07, 2008 1:11 pm
found the problem the check valve on the cold water inlet was blocked
alangjones
Rank: Apprentice
0%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
