Post
by ianr »
Tue Apr 08, 2008 7:56 am
Sounds like air in the system as result of the pump change, if it has an auto air bleed it may be a simple case of turning on the filling loop until the pressure in the system reaches a stable presure of between 2-3 bar then turn off the filling loop. If the auto air bleed is working then the air will be removed by the addtional water.
If this doesnt cure it, I would suggest you invite your plumber back to complete the job they started.
