Noisy pipes!
Postby dwedmunds » Fri Mar 08, 2013 5:08 pm
When the central heating boiler stops there is a rumbling sound from the pipes, sometimes accompanied by a sharp knock sound. I can eliminate this by turning down the two gate valves on the pipes leading to the hot water tank in the airing cupboard but only if the valves are turned about 75% off. What causes this & how can I overcome the problem without having to turn the valves down so low? Apart from this the CH system works OK.
dwedmunds
Rank: Apprentice
Progress to next rank:
26.3%
Sponsor
Simply Build It
Postby diydoctor » Mon Mar 11, 2013 12:57 pm
Check out our project on Noisy Pipes http://www.diydoctor.org.uk/projects/noisypipes.htm
Thanks for posting
The Doctor
diydoctor
Rank: Apprentice
73.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
