oil central heating boiler
Postby trevkit » Wed Aug 18, 2010 4:44 pm
I have to move a wocester oil combi boiler to another room, am I right in thinking that its electric off, oil off, water off then drain from the bottom of the boiler?there is 2 drain cocks do I drain from both? It looks like the 22mm pipes at the back will remove ok with one needing cutting, what will happen to the water in the radiators? do I have to drain everything?
trevkit
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby stoneyboy » Thu Aug 19, 2010 5:37 pm
trevkit,
Close all radiator valves then drain the water from the drain cocks until it stops running.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
