oil central heating problem
Postby ian0109 » Fri Feb 06, 2009 9:42 am
We have an Oil Central Heating System with honeywell control.Recently the water in the main hot water tank is heating up when only the heating control is on.I do not really understand this,could there be a problem with two way valve.We only use the system with either hot water or heating on but not both together.Any advice would be appreciated.
ian0109
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby stoneyboy » Fri Feb 06, 2009 5:32 pm
ian0109,
Assuming that in the past you could select CH only, then the motorised valve sticking partly open is the most likely cause.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
