one radiator not working
Postby goobowl » Fri Feb 15, 2008 6:22 pm
have moved into a new house, and the boiler and radiators work fine - bled them all and the heating is good. However, one radiator (in one bedroom) does not heat up at all. Can a radiator be disabled like this? (it's in not the end one, the one in the room past it works fine) And if it has been disabled, how do I just fiddle with the valves and try to reopen them?
goobowl
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby htg engineer » Fri Feb 15, 2008 8:59 pm
Turn both valves anti-clockwise to open them, this will probably mean removing the lockshield valve cover and using a spanner or water pump pliers to open.
If it still doesn't heat, try turning off a few of the other radiators to see if it will push through - if not, the valves may be faulty, airlock or blockage in pipework.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
