I have a 4 year old Suprima 60 L . My system is open vented fully pumped and has a Honeywell mid position Y plan valve.
My question is regarding the Control Sequence and normal way of running.
The start sequence starts as stated in the manual. However the burner only stays on for about 3 mins it then goes off (not locked out ie does not need resetting) the pump remains running (overruns for the designed 2 mins) The pump then stops just for a second or so... and the sequence starts all over again. The system runs like this until the room stat is satisfied. I have tried higher and lower settings on the boiler temperature control but if make little difference ( when temp control is lower the burner goes off after say 2 mins or so). Is this normal or should the boiler run continuously until the room stat stops it?
The above sequence also happens if hot water only is selected.
I have also tried chaning the speed setting on my pump.
- HOME
- DIY PROJECTS
- DIY TIPS AND TRICKS
- REVIEWS
- GARDENING
- DIY VIDEOS
- GREEN LIVING
- HIPS
- FIND TRADESMEN
- PRICE DOCTOR
- FORUM
- BLOG
- NEWS LETTER SIGNUP
- SHOP
- SUPPLIERS
- ADVERTISE HERE
- PRESS
