potterton suprima L60 not running hot.
Postby keithice » Tue Dec 29, 2009 6:39 pm
I have a working boiler that though running is not getting the radiators or hot water more than lukewarm... I first thought was it was a fault on the water temp sensor on the boiler so I changed the sensor.. no change.. any suggestions keithice
keithice
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby DEEARR2 » Tue Dec 29, 2009 8:50 pm
Problem may be with the gas valve not modulating up to full gas rate. Check the burner gas pressure and compare readings with manufacturers spec. If this is the case you are looking at the PCB or the modulating gas valve assembly.
DEEARR2
Rank: Ganger
73.3%
Postby ianwallisguy » Mon Jan 11, 2010 9:22 pm
I too have this problem and replaced the temperature thermistor today but no change. The problem seems to be intermittant and it will run hot for several hours before running lukewarm again. Has anyone had any success in sorting this problem?
ianwallisguy
Rank: Labourer
25%
Postby keithice » Tue Jan 12, 2010 7:12 am
Have now replaced PCB as suggested and running very well, thanks
keithice
keithice
Rank: Labourer
25%
Postby ianwallisguy » Fri Jan 29, 2010 3:48 pm
In case anyone is interested, I solved my intermitant problem by just turning the boiler thermostat down. I had turned it up to maximum during the cold weather thinking this would help heat my house better, but for whatever reason, this caused the fault described above. All running fine now.
ianwallisguy
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
