problem with over pumping
Postby barry diebelius » Wed Jan 16, 2008 2:56 pm
i have a problem with pumping over in the header tank. i cannot raise the tank any higher as it is already at the top of the rafters,the boiler and the pump are located in the loft as well.
barry diebelius
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby marrtin » Wed Jan 16, 2008 8:47 pm
Move the cold feeder pipe to a position closer to the expansion pipe (within a foot). The only reason you get an overflow or air sucked in is if there is a pressure differential between the two. Putting them closer removes the possibility of this occurring.
marrtin
Rank: Foreman
58%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
