Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    radiator not warming up to temp
    Post a reply
    3 posts • Page 1 of 1
    Postby nivek24 » Thu Sep 08, 2011 4:45 pm
    About 3years ago i replaced the room radiator with a new one.
    i took the opportunity to place the new one on a different wall, so had to move the pipes. I followed the inlet and outlet using new plastic piping.
    Since then it has not got hot like the other ones in the house.
    Last year i had a new worster boiler fitted, but still it does not get hot. Today i removed the radiator thinking it may have a blockage in it. I left it outside with a hosepipe running through it, the water flowed straight thru no problem, just a slight discoularation of the water, flushed it from both directions all clear.
    I refiited it, bled the system, problem still the same.
    The feed into the radiator has a thermostat on it, i removed the top of the thermostat thinking this may have been faulty, still same. THe feed pipe into the radiator is hot, but the one out of it is only luke warm?.
    The radiator gets warm at the top, bottom cool, but not the full length of it its like pockets. The radiator size is 79" long,12" high. double
    I have a drain on the outlet side of the radiator as this is the furthest from my boiler.
    If i close the inlet into the radiator, i can open the drain valve on the outlet and water flows out ok.
    i can't think what else to do without taking my floor up and checking the pipes.
    Kevin
    nivek24
    Top
    Re: radiator not warming up to temp
    Postby collectors » Fri Sep 09, 2011 7:05 pm
    Its likely the system needs balancing. 1st turn all the TRV,s off with the exception of the rad that's not getting hot, & make sure this rad now gets up to temperature. If yes! turn on all TVR's & find the hottest radiators in the house & turn down the radiator valve on the other end of the rad (Opposite the TRV) buy about 1 to 1.5 turns to reduce the flo to that rad. Do this on a few of the rads & see if this pushes the hot water to the problem rad.
    collectors
    Top
    Postby nivek24 » Sat Sep 10, 2011 4:21 pm
    spot on mate, i did what you said and radiator warmed up ok.
    Great. Thank you Kevin.
    nivek24
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • Two radiators not warming up
      by Roger9786 » Fri Jan 04, 2008 11:20 am
      Last post by marrtin View the latest post
      Fri Jan 04, 2008 6:21 pm
    • Heating is not warming up house quick enough
      by mandyjayne » Mon Jan 05, 2009 7:20 pm
      Last post by plumbbob View the latest post
      Tue Jan 06, 2009 10:44 am
    • BAXI SOLO 2 PF BOILER - ONLY WARMING WATER!!
      by pvanrooyen » Wed Feb 06, 2008 5:16 pm
      Last post by htg engineer View the latest post
      Wed Feb 06, 2008 9:30 pm
    • room not getting enough temp
      by jobin jose » Wed Feb 13, 2008 8:23 pm
      Thu Feb 14, 2008 3:40 pm
    • iconsistent hot water temp !!
      by misery » Wed Dec 08, 2010 7:48 pm
      Last post by Cheesie1 View the latest post
      Thu Mar 24, 2011 5:15 pm
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
