Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    Radiator Sizing
    Post a reply
    5 posts • Page 1 of 1
    Radiator Sizing
    Postby Treehugger » Wed Jan 16, 2013 5:11 pm
    I want to replace two old radiators in my living room. I'm not sure what size to install as most calculation sites only give caluclations for one radiator - my query therefore: is the BTU required the same when fitting two radiators or can this be reduced?
    Treehugger
    Top
    Re: Radiator Sizing
    Postby Atticus Finch » Wed Jan 16, 2013 5:37 pm
    Treehugger wrote:I want to replace two old radiators in my living room. I'm not sure what size to install as most calculation sites only give calculations for one radiator - my query therefore: is the BTU required the same when fitting two radiators or can this be reduced?
    The figure provided by on-line calculators is just the heat loss for the room; they then assume you only need one rad. If you want to divide this between two, three or even four rads, you can.
    So a 2kW loss can be provided by: one rad of 2kw; two rads of 1 kW each; or one rad of 1500W and one of 500W; or even two rads of 800W and one of 400W.
    Which calculator have you been using? Many of them are very suspect. This one gives sensible results.
    Atticus Finch
    Top
    Re: Radiator Sizing
    Postby Treehugger » Wed Jan 16, 2013 8:18 pm
    Thanks for that. I have used the calculator you suggest but note that several others come up with diferent figures. It appears that I can replace my old radiators with much smaller modern convection type ones and had been wondering if having two radiators, i.e. one at each side of the room would create some form of improved convection effect thus perhaps reducing the overall size required. I have in fact a fairly small room, only 3.1 x 4.85, it also has a working coal fire so I a am losing a lot of wall space hence why I was seeking to reduce the replacement radiator size's. My walls are also 600mm thick solid stone and the BTU calculator's don't have an option for this - again I am thinking that the thermal mass of the walls would have an effect on the BTU requirement
    Treehugger
    Top
    Re: Radiator Sizing
    Postby Atticus Finch » Thu Jan 17, 2013 11:57 am
    Treehugger wrote:I have used the calculator you suggest but note that several others come up with different figures.
    You will get different results from online calculators. It all depends on the assumptions they make and the methodology used. Some have glaring errors. The one I suggested has no errors, the methodology is correct and the assumptions are sensible.
    My walls are also 600mm thick solid stone and the BTU calculator's don't have an option for this - again I am thinking that the thermal mass of the walls would have an effect on the BTU requirement[/quote]
    The U-value of a 600mm stone wall is between 1.4 and 1.68. The on-line calculator uses these U-values: Brick cavity - 1.5; Solid brick 200mm - 2.1. If you entered 'brick cavity' into the calculator, you will get a result which is reasonably close to the correct loss for your room.
    The thermal mass does not affect the heat loss; all it does is help iron out the fluctuations in internal temperature. Don't forget that the heat loss calculation gives you the amount of heat required to bring a cold house at -1C up to 21C when it is -1C outside.
    Atticus Finch
    Top
    Re: Radiator Sizing
    Postby Treehugger » Fri Jan 18, 2013 9:16 am
    Many thanks, your advice has been of great assistance.
    Treehugger
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • sizing radiator pipes
      by michaelt » Sat Mar 24, 2007 11:28 pm
      Last post by thedoctor View the latest post
      Sun Mar 25, 2007 7:14 am
    • F AND E TANK PIPE SIZING
      by kezdave » Fri Oct 03, 2008 12:41 pm
      Last post by Steve the gas View the latest post
      Sat Oct 04, 2008 4:31 am
    • Sizing radiators for condensing boilers
      by Pritchard » Mon May 28, 2007 3:46 pm
      Last post by Pritchard View the latest post
      Thu Jun 21, 2007 8:23 pm
    • Replacing radiator with Towel radiator
      by debbia » Mon Mar 09, 2009 12:08 pm
      Last post by htg engineer View the latest post
      Mon Mar 09, 2009 5:05 pm
    • HOT RADIATOR
      by greengrass » Mon Nov 12, 2007 1:21 am
      Last post by greengrass View the latest post
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
