Radiators between heat cycles
Postby mcslemon » Mon Feb 16, 2009 6:33 pm
Just had some rads in my lounge replaced (got some bigger ones supplied by my builder) but I'm finding it a bit odd that when the heating clicks off between cycles, the rads seem to cool down fairly quickly. Is this normal between cycles? I've had centrally heated homes before but never really noticed (not that I checked)).
Any thoughts would be appreciated.
Cheers.
Neil
mcslemon
Rank: Apprentice
Progress to next rank:
10.5%
Sponsor
Simply Build It
Postby htg engineer » Tue Feb 17, 2009 9:13 pm
Not sure I understand the post, do you mean when the heating goes off the radiators cool down quickly, or the radiators cool then warm up again (with trv's fitted htis is normal).
The radiators can cool down failry quickly when the heating goes off, the rate at which they cool depends on the amount of water in the system, insulation to the property and the temperature of the rooms.
htg
Rank: Project Manager
Postby mcslemon » Tue Feb 17, 2009 10:23 pm
Yeah.. I think that's what I mean.
Just to discuss. Basically, heating clicks on via the thermostat and boiler goes on and rads heat up. When it clicks off again, the rads cool quickly until the boiler comes back on. As the house warms up, the boiler doesn't stay on as long so the rads don't heat up as much which seems to defeat the object.
mcslemon
Rank: Apprentice
10.5%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
