RADIATORS DOWN STAIRS DONT WORK !HELP!
Postby jimbobain » Sat Nov 29, 2008 10:00 am
HI HOPE SOMEONE CAN HELP ME MY PROBLEM IS MY RADIATORS ARE WORKING UP STAIRS BUT NOT DOWN STAIRS THE PUMP IS OK BUT I HAVE NOTICED THAT THE RETURN PIPE TO BOILER IS COLD . IF YOU TURN OFF ALL UPSTAIR RADS THE ONES DOWN STAIRS DOES WORK APART FROM ONE COULD THE PROBLEM BE A BLOCKAGE IN THE RETURN PIPE? IF IT IS HOW DO YOU UN BLOCK IT THANKS ,JIM
jimbobain
Rank: Labourer
Progress to next rank:
75%
Sponsor
Simply Build It
Postby htg engineer » Sat Nov 29, 2008 12:02 pm
Check pump.
htg
Rank: Project Manager
Postby jimbobain » Sat Nov 29, 2008 12:45 pm
THANKS FOR YOUR REPLY , THERE WAS A NEW PUMP FITTED AT THE START OF THE YEAR.
jimbobain
Rank: Labourer
75%
Postby Steve the gas » Sat Nov 29, 2008 4:57 pm
Hi Jim,
Please turn your caps lock off.
Pump airlocked, take screw out of middle (water) to bleed.
Steve the gas
Rank: Site Agent
56%
Postby jimbobain » Tue Dec 02, 2008 2:05 pm
thanks for your reply pump was bled but still same problem when the pump was changed it was from a grundfos selectric 15-50 to a flowson, spec for both are the same ( but flowson cheaper) could this be the problem?hope you can help cheers
jimbobain
Rank: Labourer
75%
Postby Steve the gas » Wed Dec 03, 2008 4:55 am
If you mean it was bled when it was fitted,then that was a while ago.Try bleeding it again -could be air in it now
Steve the gas
Rank: Site Agent
56%
Postby jimbobain » Thu Dec 04, 2008 9:19 pm
EEEEEEEHAAAAAAAAAAAA SORTED IT WAS A FAULTY PUMP NEW ONE FITTED AND IT NOW WORKING OK ,THANKS FOR YOUR HELP LADS KEEP UP THE GOOD WORK ,JIM
jimbobain
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
