radiators getting hot when not supposed to
Postby cdk7474 » Sat Apr 25, 2009 5:13 pm
This afternoon the radiators started getting hot even though the thermostat was turned right down, I switched the switch on the front of the boiler (Potterton performa 24) to water only and the boiler was still fired up. I also switched the timer control to the off position and it was still alight, so now ive turned it off completely, Any suggestions or reasons for this would be much appreciated thanks.
cdk7474
Rank: Apprentice
Progress to next rank:
5.3%
Sponsor
Simply Build It
Postby Steve the gas » Sun Apr 26, 2009 6:23 am
This suggests that the diverter valve is passing hot water into the heating circuit.
Steve the gas
Rank: Site Agent
56%
Postby htg engineer » Sun Apr 26, 2009 8:58 am
Check sensors/frost stat.
htg
Rank: Project Manager
Postby cdk7474 » Mon Apr 27, 2009 4:41 pm
thanks peeps for the information/advice, will take a look and get back to, thanks again
cdk7474
Rank: Apprentice
5.3%
Postby arnauda » Mon Apr 27, 2009 4:48 pm
I have a similar problem. The central heating is switched off but when the hot water timer comes on , the radiators are getting hot.
If it is the diverter valve, how costly is it to have this repaired by an engineer?
arnauda
Rank: Labourer
25%
Postby Steve the gas » Tue Apr 28, 2009 4:42 am
Depends on the RGI but I would say about £80 + parts
Steve the gas
Rank: Site Agent
56%
Postby bd3cc » Wed Apr 29, 2009 11:40 pm
It does sound like the diverter valve.
these can be replaced easily, as it is the actuator or head which is at fault, and the just screw on/off. Any one can do it,=. Just note the model number, go to a plumbers merchants get the actuator, and refit. take a note of the electrical conections, make sure to turn off at mains and refti/ recoonect exactly as was.
bd3cc
Rank: Foreman
41%
Postby htg engineer » Thu Apr 30, 2009 6:21 pm
bd3cc - isn't the Potterton Performa 24 a combi boiler ?
Therefore it will have a diverter valve ?? not a three port valve as you're describing - big difference and not easy to change if you're not sure what you're doing!!!
htg
Postby rosebery » Thu Apr 30, 2009 11:30 pm
Surely a three port valve can reasonably be described as a diverter valve?
(puts wooden spoon back in drawer!!)
rosebery
Postby htg engineer » Fri May 01, 2009 3:35 pm
If you actually read the post I am not saying a three port valve cannot be described as a diverter - the point I was making is that it's a combi - he is saying to change the actuator head/motorised valve - if it's a combi it might not have one, if it does - it might not need re-wiring.
If people want the correct advice they need to give the correct info - as a TRADESMAN I am explaining that there is a between a three port diverter valve and a diverter valve, the motorised head or actuator cannot be changed as described.
It can be described as a three port diverter valve, or a two port diverter valve. But 'diverter valve' alone would normally be taken as referring to a combi boiler
I have asked before and you either refused to reply or didn't see my post, I asked if you were in the trade or had any trade behind you ? without the reply I have to assume not. I am - the advice I offer is correct.
If it's a hydraulic diverter valve, where's the actuator/motorised valve ? how would I change it ?
htg
Postby rosebery » Sat May 02, 2009 10:41 pm
I was pulling your leg!!!!!!!!!!
wasn't it obvious??
obviously not!
rosebery
Postby htg engineer » Sun May 03, 2009 9:13 am
Sorry - missed the - (puts wooden spoon back in drawer!!) part of your post.
I assume that was to indicate you were 'pulling my leg'. Although haven't a clue what it means, must be a regional thing ? or an age thing as i'm only 25.
Or is that the clue to your trade ? baker or chef ? lol
Thanx
htg
Postby rosebery » Sun May 03, 2009 10:25 am
Wooden spoons are for stirring!
Hadn't thought of it as a regional thing - thought it was universal.
Age thing nah! Age and cunning will overcome youth and enthusiasm any day.
Probably make more money as a chef.
rosebery
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
