radiators not hot enough
Postby webbo1975 » Fri Jan 09, 2009 4:15 pm
Boiler is on max but radiators do not get that hot more like luke warm this is a back boiler not sure of the make maybe glowworm. All radiators have been bleed but still the same and water get red hot. Would draining the whole system make this any better? Or any other ideas? Thanks Chris
webbo1975
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby DEEARR2 » Fri Jan 09, 2009 8:07 pm
It is often the case that back boilers feed the heat to the hot water system via gravity and the heating system is pumped. I would check that the pump is running firstly.
DEEARR2
Rank: Ganger
73.3%
Postby Steve the gas » Sat Jan 10, 2009 8:20 am
Spose it could be sludged up-- so draining and refilling a few times may help.
Dont forget inhibitor when you refill the last time tho.
Boiler stat could be at fault also.
Hth
Steve the gas
Rank: Site Agent
56%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
