RADIATORS
BOILER
RADIATORS
by BOILER » Mon Oct 25, 2010 10:03 pm
My existing gas central heating system is soon to have all the old radiators replaced. Should I ask the plumber to fit isolating valves to the inlet/outlet pipework on each of them. Would this eliminate the need to drain the whole system if at a later date there was a problem with a single radiator?
Many Thanks
by htg engineer » Tue Oct 26, 2010 12:00 pm
No need - that's what radiator valves are for.
htg
BOILER
by BOILER » Sun Oct 31, 2010 10:15 pm
htg engineer wrote:No need - that's what radiator valves are for.
htg
Thanks htg engineer, I assume that additional isolating valves for each rad would only be benificial if the TRVs and lockshields were also to be replaced as well as the radiator, therefore eliminating the need to drain the whole system.
