RECOMMENDATIONS FOR A SHOWER SYSTEM?
Postby jon11 » Fri Jan 23, 2009 4:07 pm
:D Hi, I am renovating a property in France & was hoping someone could recommend a suitable system for shower & bath. The system would need to run off electric as there is no gas & I would not want to use an oil based heating system. I would like to install a bath & shower on the first floor and a shower on the ground floor. There is no loft space so I assume a hot water tank would need to be in the bathroom. The water pressure is good, would it have sufficient pressure to run the shower off or would it need boosting. There is also the issue that the property is vacant for long periods of time & the water is turned off at the mains. Does anyone have any suggestions, many thanks Jon.
jon11
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby Skids » Fri Jan 23, 2009 7:51 pm
Hi jon11
why not try a 9.5 electric shower, easy to install, can be isolated as required, cheep to run, only heat the water when you use it, cost £100 - 150.
Bargain
Regards
Skids
If you need some one to fit it during the hot summer we all deserve, it would take the family (me) two weeks, what part of French did you say, lol
Skids
Rank: Ganger
52%
Postby jon11 » Mon Jan 26, 2009 3:54 pm
Skids, many thanks for your reply, yes I agree the shower only option would be considerably easier. I assume the only way to get the water for the bath is a tank/immersion. I guess you couldnt run a gravity fed shower off that as there wouldnt be enough pressure or is this possible. Im not bothered about the bath but 1 member of my family only has baths. If I did put the tank in are there any issues with regularly turning the supply off at the mains? Also many thanks for the offer of installation, there is a fair bit to do in terms of installing the sink toilet & soil pipe, there may also need to be some rewiring so will prob get 1 of the locals who has been recommended. The place is 1 hr inland from La Rochelle in a medieval village called Vouvant. Its a bit of a long term project, but with things fairly quiet in the Uk at the moment is a good opportunity to get things done. In the fllooring trade myself. If ur still interested in heading over in the summer can sort out a v favourable rate (assuming it all gets done) rgds Jon
jon11
Rank: Labourer
25%
Postby TheDoctor5 » Thu Jan 29, 2009 2:29 pm
TheDoctor5
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
