Replace Back Boiler with COmbi
Postby Skinner.Daddy » Thu Dec 18, 2008 12:43 pm
Hi Guys,
Looking at replacing an old(10 years ish) back boiler with a new combi boiler in the loft and getting rid of the header tank and other tank.
Any one done this and what sort of Savings did you get on heating bills etc?
Also a guy I know used all push fit plastic pipes for a house re fit of CH, are they ok to use throughout the house?
Skinner.Daddy
Rank: Apprentice
Progress to next rank:
15.8%
Sponsor
Simply Build It
Postby htg engineer » Thu Dec 18, 2008 9:08 pm
There's alot of work to fit a boiler in the loft :
-You need lighting installed (not temporary lights)
-loft floor needs to be boarded at least a walkway and an area around the boiler
-Fit handrails around the loft hatch
-Have loft ladders installed (can't use step ladders for access)
-You need an electrical socket near the boiler, for testing equipment etc.
-There has to be an ECV fitted to the pipework before it enters the loft.
etc etc.
As for the pipework - i'd go for copper everytime.
htg
Rank: Project Manager
Postby Skinner.Daddy » Thu Dec 18, 2008 9:27 pm
[quote="htg engineer"]There's alot of work to fit a boiler in the loft :
etc etc.
htg[/quote]
Thanks for the reply
Nothing sounds too difficult there.
I have a fixed pull down loft step ladder, is that ok?
Already light, floor boards and electric sockets in the loft so thats fine
And can fit hand rail round inside of loft hatch easy enough.
Why do you say use copper? It's more expensive harder to work with and longer to fit.
Thanks for the advice
Skinner.Daddy
Rank: Apprentice
15.8%
Postby htg engineer » Fri Dec 19, 2008 2:31 pm
Copper pipe with soldered fittings wont fail if cleaned and soldered properly, plastic push-fit fittings can and do fail, I have sen the damage in brand new apartments where a push fit fitting has come apart.
I wouldn't have it in my house, that's why I wouldn't recommend it for anyone else. I've never used it, but would if a customer insisted.
htg
Postby Steve the gas » Fri Dec 19, 2008 7:16 pm
I've used it, its ok, but copper upto rads.
It's ok as long as you are careful with the fittings.
Steve the gas
Rank: Site Agent
56%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
