Replacement room stat doesn't work
Postby maljm » Sat Apr 12, 2008 7:52 pm
Hi. I have replaced an old mechanical stat (Tower Flue Components type DT) with a Drayton RTS1 but doesn't work. Three connections + earth on old stat are called "break on temperature rise", "common" and "spare" (marked N). Have connected to RTS1 as demand, common and neutral. Any thoughts?
maljm
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby maljm » Tue Apr 22, 2008 6:53 am
Problem solved. Invensys technical department very helpful. Fault was with connections in junction box. Using a Y plan wiring diagram discovered that live and demand were reversed. Corrected the fault and new stat works fine.
maljm
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
