sealing up air vent
Postby jason h » Fri Jan 02, 2009 8:37 pm
recently had new fire fitted - living room has low level air vent which is no longer needed (on corgi installers advice) and looking for advice on best low cost/highly effective way to seal up, to prevent draught in living room, as front of property is exposed to all weathers and can prove v. draughty and noisy
jason h
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby plumbbob » Sat Jan 03, 2009 4:20 pm
In the past I have removed the internal cover and filled the cavity with polystyrene foam blocks salvaged from carton packaging.
plumbbob
Rank: Project Manager
Postby Perry525 » Sat Jan 03, 2009 5:04 pm
I presume you now have a balanced flue fire?
If so squirt a can of poly foam into the space, that will give you a perfect seal, that is far warmer than anything else.
Perry525
Rank: Site Agent
46.8%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
