Speedfit Fittings
Postby marks1x » Mon Jul 09, 2007 7:18 pm
Hi, I wonder if any plumbers out there can help me. I have had a full central heating system fitted by a young corgi registered plumber who used fittings specified by and supplied by me. Most, if not all, radiator tails are in chrome plated copper and the Speedfits go straight onto the tails. Subsequently I have spoken to John Guest ( Speedfit ) and they advised that their fittings should not go onto chrome pipe as the surface is too hard for the teeth to bite into and could blow off.
A: Is this true, as some of the plumbing is now un-accessible.
B: They advised that some chrome should be removed from the end of the pipe, I have tried and it seems impossible.
marks1x
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby oldie » Thu Jul 12, 2007 9:53 pm
Advice correct.
Should follow it if possible.
If heating system is gravity fed from an open albeit covered expansion tank you might get away with it for a bit.
If it is pressurised, then get it sorted quickly before your luck runs out.
oldie
Rank: Apprentice
42.1%
Postby marks1x » Fri Jul 13, 2007 2:31 pm
Thanks for that. What remedial action should I take? Do I put a compression fitting onto the chrome with another copper tail and re-fit the speedfit, messy!
marks1x
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
