Post
by marrtin »
Sun Dec 30, 2007 9:13 am
Do not put the heating on until it is full of water. It could cause irreparable damage.
The reason the header tank will not fill is due to a stuck ball cock. This often happens in heating systems. Waggling it about is often sufficient to free it. If the float moves up and down freely, then it is probably totally seized and needs dismantling or replacing.
This valve could very well be the cause of your original problem.
You could as a last result refill the system manually but the faulty ball cock must be repaired asap.
<<< IGNORE THESE INSTRUCTIONS IF YOU HAVE A COMBI BOILER.>>>>
Sorry I did not notice you mentioned this fact. Combi's need to be filled using the filling loop near the boiler. The small heating header tank in the loft is unused, and should have been removed when the new boiler was installed.
