Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Plumbing
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    The best method to connect pipes?
    Post a reply
    3 posts • Page 1 of 1
    Postby Adam » Tue Mar 20, 2007 12:39 pm
    I'm about to fit in a new bathroom suite & I need to run a waste & hot & cold pipes under the floor so I want to use pipe connectors that will last.
    I suppose its a matter of opinion but which pipe connectors are best? Compression, push-fit or solvent wield or O ring? Basically which ones last the longest. Any ideas?
    Also can you connect new plastic pipes to old copper pipes for the water inflow?
    Adam
    Adam
    Top
    Postby sparty » Wed Mar 21, 2007 1:16 pm
    Adam, you can use any of those type of fittings. Obviously the yorkshire fittings, solder, are the cheapest. You can get them with the solder ring in so all you have to do is apply heat, or you can solder them yourself. However, push fittings are the easiest and quickest way of doing the job. I prefer the speedfit ones as I find them easier to remove than the Hep2o ones. Provided you get them on straight first time they are dead easy. They will last just as long as any other fitting. You can attach plastic pipe to copper pipe no problem, again you can use the push fittings (don't forget the pipe inserts if you are using plastic pipe!!). Just a tip, have some washing up liquid to hand, smear a bit on the pipe before fitting the push fitting, it helps things along nicely.
    Hope this helps.
    Andy
    sparty
    Top
    Postby sparkyspam » Sat Mar 31, 2007 4:12 am
    I wouldnt use any joins in an inaccessible area if possible. Just bend the copper to where it has to go. w.r.t. pvc waste pipes, I'd use 'solvent cement'. Cant hurt to wrap some 'rubberweld' tape around the pvc joins to boot.
    well thats what I did under my wetroom floor and I dont want ever want to have to dig the tiles up there.
    sparkyspam
    Top
    Post a reply
    Return to Plumbing
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • How to connect 2 appliance's waste pipes of different sizes
      by martin_y » Sun Nov 07, 2010 4:59 am
      Last post by martin_y View the latest post
      Tue Nov 09, 2010 3:45 pm
    • What do I need to connect Mixer Tap tails
      by hereigoagain » Tue Feb 12, 2013 4:48 pm
      Last post by stoneyboy View the latest post
      Thu Feb 14, 2013 12:04 am
    • Can I connect radiator return to ANY point?
      Attachment(s) by jonnyplatt » Wed Jul 18, 2012 2:26 pm
      Sun Jul 22, 2012 8:32 pm
    • Connect Dish Washer & Washing Machine
      by Gregs Helper » Wed Apr 04, 2007 9:30 am
      Last post by thedoctor View the latest post
      Wed Apr 04, 2007 5:55 pm
    • How to connect 1" hose to 15mm internal pipework?
      by ardmayle » Wed Mar 28, 2007 1:09 pm
      Last post by tamz View the latest post
      Thu Mar 29, 2007 7:20 pm
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
