The correct way to crimp wires
Postby Dadwood » Fri Feb 20, 2009 2:10 pm
Having drilled through the twin and earth suppy to a 13amp socket outlet, we are told it is OK to use butt crimps to make the repair. But is it best if we use parallel insulated crimps, or would those with funnel ends be better? Also, when making the repair do we strip back sufficient insulation from the two damaged ends so that both ends will go right through the crimp (one put in from each end)?
Dadwood
Rank: Ganger
Progress to next rank:
9.3%
Sponsor
Simply Build It
Postby kbrownie » Fri Feb 20, 2009 7:22 pm
HI Dadwood,
I use the Insulated Crimp Terminal - Butt Splices, which are just a straight insulated coupler. You'll find they will not be to much room for the cables to cross over within the butt. So need to make sure you make enough off cable to enter butt without any conductor showing and get a good contact. A good pair of rachet crimps, to crimp up with would be recommended too.
Regards
KB
kbrownie
Rank: Project Manager
Postby Dadwood » Sat Feb 21, 2009 12:15 pm
Hi kbrownie, very many thanks for your advice, which I will heed when I do the repair.
Dadwood
Rank: Ganger
9.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
