The render is coming off my bay window
Postby Werdna » Fri Jan 10, 2014 6:40 pm
I have a 1930's semi with a bay on the front on both floors.
On the outside the section,above the ground floor window and below the first floor window, the render is falling off.
It looks like there is felt under it.
I was planning on removing it all so I can insulate it better and then board it and render it.
Can anyone give me advice on what materials to use please?
What insulation, board or felt etc and render mix?
Thank you
Werdna
Rank: Labourer
Progress to next rank:
75%
Sponsor
DIY asbestos test kits
Postby welsh brickie » Sat Jan 11, 2014 3:33 pm
you can use fiberglass insulation if you want, its up to you,
To seal it, use osb boarding 12mm thick, the cover it with roofing felt,
you will then need to use expanding metal and fix it to the bay to give the render something to grip to. The render needs to be a mix of sand lime and cement 5/1/1 with a waterproof addative, the first coat needs to be applied then scratched with a plasterers comb to give a key for the second coat
Rank: Project Manager
Postby Werdna » Sat Jan 11, 2014 5:44 pm
Thank you for your help.
Werdna
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
