The valve on the radiator is stiff - I cannot turn the heat
Postby nessas7 » Tue Oct 09, 2007 3:19 pm
I turned on my radiator after a period of 4 months for around 20 minutes. I then turned the valve off (to shut mode). Right afterwards it became stiff and now does not turn either way. What can I do. Help...Winter is on its way.
nessas7
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby nessas7 » Tue Oct 16, 2007 1:03 pm
To the people that viewed but were unable to answer my query I figured a way to solve the problem. Unscrew this at the top, apply some oil around the pin, leave for 5 minutes then use a plier to gently turn in the opposite angle (to turn on). This should release the jam. You may see slight weeping of the valve so just use a cloth/ tissue to absorb the water.
nessas7
Rank: Labourer
25%
Postby htg engineer » Tue Oct 16, 2007 4:28 pm
Sounds like you were turning the valves the wrong way, or you turned them off too tight, they don't normally seize up after 20 mins.
Opposite angle ? or direction ?
If the valve leaked when you opened it, it's probably still leaking now.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
