Thermostat Electrics
Postby paul100 » Mon Jul 21, 2008 3:17 pm
This query might be related to the 'Electrics' forum, so I've posted the topic there too.
A few weeks ago when I turned on my hot water, the CH came on also. When I turned the hot water off, the CH remained on. A heating engineer called out, who said the electrics in the thermostat were old, in a poor state of repair and needed replacing. He advised that an electrician would need to do the work. However, when the electrician called out he said that it's a heating engineer's job. I'm stuck. I would have thought that replacing wires in a thermostat would be an electrician's responsibility. Any advice would be much appreciated.
Thanks,
Paul
paul100
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby sparx » Mon Jul 21, 2008 9:45 pm
see my reply on electrics forum, regards Sparx
Rank: Project Manager
Postby htg engineer » Tue Jul 22, 2008 11:08 am
The problem points to the actuator/3 port valve.
If the heating is working, the thermostat and wiring will probably be ok. As the thermostat calls for heat which will send a signal to the actuator to open for CH. Which it is doing.
I don't know many electricians that will work on central heating controls. They tend to work up to the fused spur - from the fused spur they tend to say it is a Heating Engineer's job. I have had many jobs passed to me where electricians couldn't or wouldn't do electrical work - not sure why, incapable or lazy ??
htg
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
