thermostat on direct cylinder wont go any higher after changing pump
Postby james_baillie » Sat May 28, 2016 3:15 pm
hi guys probably normal but i changed my heating pump and unions. then i had a problem with boiler micron 30 ff. i had to change the PCB. have also ballanced rads . now i noticed the cylinder thermostat was set over 60. so pump wouldnt switch off as it could never get to temp. i turned it down to 50 same as next door with same setup and all is fine
my question is why cant ut go any higher then 50. im sure it used to past 50. i didnt notice old pump staying on . if it was it was quiet.
thanks
james_baillie
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
  • DIY How to Project Guides
  • Related Topics
