thermostat problems
Postby michael hurn » Sun Dec 30, 2007 5:24 pm
hi i have my central heating boiler working with a drayton p711 timeswitch and an rst1 thermostat. thermostat reaches desired tempreture and then cuts out, but when room temp drops it fails to call for heat. do you its faulty or a possible wiring problem
michael hurn
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby marrtin » Mon Dec 31, 2007 5:43 pm
My guess is the thermostat is faulty, but it is difficult to be sure without testing it.
marrtin
Rank: Foreman
58%
Postby htg engineer » Mon Dec 31, 2007 6:15 pm
Could be a faulty thermostat, If it's just started and has previously worked. Then it's not going to be a wiring problem unless you've had work carried out or someone has been fiddling.
Try renewing the thermostat first, not expensive and easy to do.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
