Thermostatic Mixer Shower Fitting
Postby spluffy » Tue Mar 17, 2009 8:30 am
I have just recently purchased a thermostatic mixer shower and need the following advice.
Basically "how do I connect the water supplies to the mixer body"
The mixer body has a hot and cold inlet (left and right entry) and the outlet that goes vertical.
All three are internaly threaded 3/4" or 19mm. There are no connectors supplied with the shower. What type of connector should I use?
Many thanks
Paul
spluffy
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby htg engineer » Tue Mar 17, 2009 7:38 pm
Have you bought this on the cheap ? if not then there's some bits missing, it should come with all connectors.
Something like: http://www.screwfix.com/prods/82086/Plu ... ler-15mm-x
in chrome
Will do the job, but may not look that good, if surface mounted.
htg
Rank: Project Manager
Postby rosebery » Tue Mar 17, 2009 9:33 pm
If its a recessed valve then you might not have the connectors with it as it will depend on how it is piped whether a straight coupler or a right angled coupler is required.
HE is correct - use 3/4" x 15mm connectors.
rosebery
Postby plumbbob » Wed Mar 18, 2009 8:55 pm
Bristan are devils for not supplying all necessary bits for BIV's. Considering how expensive the valves are, it is really annoying to have to go shopping every time I open a box.
plumbbob
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
