Price Doctor - Extension quote and price checking software
Save up to 50 percent off subcriptions to some of the best DIY and Home Improvement magazines
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Bathrooms, drainage and waste plumbing
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    thermostatic mixer shower
    Post a reply
    2 posts • Page 1 of 1
    Postby mikestone » Sun Dec 09, 2012 2:53 pm
    I am fitting a new thermostatic mixer shower in my bathroom to replace an old Trevi Therm 310 which worked well but has finally given up the guost! I have a low pressure system with 22m pipes directly from the cold water tank and the hot water cylinder feeding the shower. The height from the shower head to the cold water tank is about 2 metres so I guess I have no more than 0.2 bar pressure. I want a setup that will provide the most flow from the shower head but I do not want to fit a pump. Anybody have any advice, preferably naming models and quoting flow rates that will at least equal the old Trevi performance, as it seems difficult to get this info from brochures and salespeople! I am also aware that there are some models out there (like the old Trevi) that have 3/4" inlets rather than 1/2" inlets and I believe that they would provide better flow rates - is this correct?
    mikestone
    Top
    Re: thermostatic mixer shower
    Postby Dave From Leeds » Tue Dec 11, 2012 3:17 am
    Don't know too much about thermostatic mixer showers. However I would imagine that, if the cold water supply to your current shower comes from the same cold water storage tank that feeds your hot water cylinder, you should have balanced flows of hot and cold at the shower head. If that is the case and you can acquire a shower that is suitable for a low pressure system you ought to get adequate flow from it. In this case I'd keep the 22mm pipes and reduce them to suit the new shower inlets as close as possible to the shower mixer.
    If, however your current shower is fed directly with mains cold water you may need to incorporate a pump into the hot water side of the shower to achieve a balanced supply.
    Bear in mind I'm only a DIYer myself and have no expertise in such matters. I'm simply applying logic to the situation you report.
    Dave From Leeds
    Top
    Post a reply
    Return to Bathrooms, drainage and waste plumbing
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • Need a thermostatic mixer shower with adjustable pipe centre
      by richhe » Tue Sep 22, 2009 3:21 pm
      Last post by plumbbob View the latest post
      Tue Sep 22, 2009 10:58 pm
    • thermostatic shower may need a service?
      by 6sunrise » Thu Feb 04, 2010 4:27 pm
      Last post by 6sunrise View the latest post
      Sat Feb 06, 2010 10:23 am
    • Thermostatic shower problem
      by tams » Sun Jan 09, 2011 6:13 pm
      Last post by stoneyboy View the latest post
      Sun Jan 09, 2011 11:44 pm
    • Thermostatic shower vale plumbing/fault
      by Randy79 » Fri Jul 30, 2010 12:03 pm
      Sat Jul 31, 2010 11:30 pm
    • Bristan artisan thermostatic surface mounted bar shower valv
      by richhe » Thu Dec 01, 2011 7:49 pm
      Fri Dec 02, 2011 8:16 am
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
