Thermostatic rad valves
Postby wingrider » Sun Mar 30, 2008 7:13 pm
I am going to fit thermo rad valves to my system, I have heard that it is necessary to leave one radiator without a thermostatic valve to prevent the flow from the pump having nowhere to go if all the rads were to shut off at the same time.
Is this correct ?
wingrider
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Sun Mar 30, 2008 7:46 pm
Yes that is correct, although some boiler have a bypass built in.
It's normally the bathroom radiator or the radiator in the same room as the room thermostat that would be left with the normal radiator valves fitted.
Rank: Project Manager
Postby wingrider » Sun Mar 30, 2008 8:17 pm
Thanks, thats just the info I needed.
wingrider
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
