thermostatic radiator valves
Postby gatoblanco » Wed Oct 31, 2007 9:58 pm
We have recently had a radiator fitted complete with a thermostatic valve, but it aseems to be at maximum heat whatever the valve setting even when set to 'frost'. Is it important which [b]side[/b] of the radiator the valve is on? Or is it the valve that will be faulty?
gatoblanco
Rank: Apprentice
Progress to next rank:
0%
Sponsor
Simply Build It
Postby The Heating Doctor » Thu Nov 01, 2007 5:48 pm
Its a possibility that the valve is on the wrong side, even with modern bi-directional valves there is a right way and a wrong way to fit them. What make are the valves?
The Heating Doctor
Rank: Foreman
4.7%
Postby gatoblanco » Sat Nov 03, 2007 3:40 pm
I will be able to check on the make of the Rad Valve next weekend. Watch this space and thanks for the help. Gato
gatoblanco
Rank: Apprentice
0%
Postby coaster » Sat Nov 03, 2007 5:58 pm
it is a faulty valve it is stuck open take the head off and tap the pin lightly with a hammer replace the head if this dosnt work replace the valve
best of luck
regards
andy
coaster
Rank: Apprentice
78.9%
Postby gatoblanco » Sun Nov 25, 2007 11:18 am
Thanks Andy/Heating Doctor,
Sorry for delay. Every valve in the house except the dodgy one is a TERRIER II. The dodgy one (the only one that the plumber had in his van) is a DRAYTON. The drayton has a white 'collar' around the middle and a chrome top. I tried lifting the chrome top to see if there was a pin to tp, but it wouldn't budge so no joy there. I have a feeling what your advice is going to be so I guess it's off to buy another TERRIER II and change it. Is the TERRIER II "Bi-Directional" ?
Gato
gatoblanco
Rank: Apprentice
0%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
