Thermostatic shower bump start
Postby forreq » Sun Jul 08, 2007 9:34 am
I have two thermostatic showers (different rooms) in a system arrangement.
Both showers have more than 1 metre of head pressure.
One shower has a pump and the other is gravity fed.
The problem is that both showers need to be turned to their lowest setting to start the flow.
Sometimes this is not enough and require a 'bump start' by allowing water flow from the basin hot tap.
Does anyone know if this is usual or whether something's away?
forreq
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby plumbers1 » Fri Jul 20, 2007 10:11 pm
The length of the supply pipe is to long for the pressure to drop enough for the pump to start. You need a negative head pump.
plumbers1
Rank: Tradesman
53.8%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
