Thermostatic shower
Postby GARYF » Sun Jun 17, 2007 8:27 pm
Hi, i have a Vokera combi boiler and want to fit a thermostatic shower. As the cold water is direct from the mains and the hot from the combi, will this be a problem?
Gary.
GARYF
Rank: Apprentice
Progress to next rank:
47.4%
Sponsor
Simply Build It
Postby plumbers1 » Sun Jun 24, 2007 8:15 pm
Most good quality shower valves eg mira excel will have a balancing washer/restrictor that will need to fitted. this will balance the pressure and volume of the cold supply versus hot supply volume.
plumbers1
Rank: Tradesman
53.8%
Postby DONFRAMAC » Mon Jun 25, 2007 1:40 am
Thermostatic (blender) showers, need both hot & cold pressures to be equal, and combi-boilers are not known for giving enough flow for showers, even if you went to the trouble of fitting a cold header-tank in the loft just to feed your shower;-- you would just be plagued by chilly spells during showers, whenever another hot water outlet opened ( Kitchen sink or washing M/C).
A high-power electric shower, perhaps incorporating a pump, seems a reasonable way forward.
DONFRAMAC
Rank: Ganger
96.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
