thermostatic shower valve problem
Postby paul_handyman » Thu Oct 11, 2007 9:01 am
I fitted a new thermo shower valve about 2 years ago but I now have a problem with it.
There is no hot water coming through.
The power pump is working ok.
The hot water is getting as far as the valve itself - (pipes are hot up to the valve)
I suspect that it is the thermostat itself inside the mixer valve that has stopped working.
Is it possible to open these valves for maintenance and is the thermostat part replaceable?
Can anybody suggest how I can test the thermostat or suggest any other cause for this before I pay out for a new valve?
paul_handyman
Rank: Apprentice
Progress to next rank:
10.5%
Sponsor
Simply Build It
Postby paul_handyman » Sat Oct 13, 2007 10:22 pm
I have still not sorted this problem.
Can anybody give me advice?
paul_handyman
Rank: Apprentice
10.5%
Postby bobplum » Sun Oct 14, 2007 7:42 pm
hi can i ask how much this valve costed if shall we say cheap then the answer is simple replace if expensive get on to the manufactures and see about guarantees and engineers
good luck
bobplum
Rank: Foreman
54.7%
Postby Bay Plumbing » Sun Oct 21, 2007 10:53 am
Hi Paul,
Firstly turn the supplies off to the shower,remove the thermo shower body and check the in-lets for dirt,debrior lime scale if your'e in hard water area,your in-let may have a fillter on them,you can flush these out under a tap,and replace the shower body and test.
hope this helps good luck
Mark
p.s it shouldn't matter if your shower cost you alot or little when it's working your not standing there thinking i'm under my shower i bought for X amount so don't go spending out just yet!!
Bay Plumbing
Rank: Tradesman
61.5%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
