TRV - Shutting off
Postby coastiefrank » Tue Mar 23, 2010 12:34 pm
I have a TRV that I need to shut off so I can remove the rad and then get the system running after it has been shut off. The lowest setting is a frost setting which means that although I can remove the rad, when I try to pressure the system back up water comes out of the TRV. I guess this is because at the frost setting the TRV is not fully shut off, so how do I shut the valve fully off? :?:
coastiefrank
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby stoneyboy » Tue Mar 23, 2010 10:56 pm
coastiefrank,
There should be a screw-on cap which replaces the trv head this turns off the water completely.
Rank: Project Manager
Postby coastiefrank » Thu Mar 25, 2010 1:07 pm
Thank you stoneyboy, I'll try to find/get one.
coastiefrank
Rank: Labourer
25%
Postby plumbbob » Fri Mar 26, 2010 6:26 pm
You will have difficulty buying the cap as a separate item. Temporarily shut the valve off by fitting a small coin such as a 5p between the thermostat head and the pin in the valve.
If the valve is to be left unattended for any time, buy 1/2" and/or 3/4" caps to block the water connections then no accidents can occur!
plumbbob
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
