Underfloor heating bathroom
byre15
by byre15 » Thu Oct 25, 2007 3:35 pm
I have just had an underfloor heating mat layed under tiles.
But the probe was not installed !!
The tiles cannot now be lifted and re layed.
Does anyone now of a way round this BIG problem, such as a surface sensor ?
Thank you
by htg engineer » Thu Oct 25, 2007 7:52 pm
I take it you mean the probe as in the thermostat ?
I can't imagine there being any other way of controlling the temperature - the best thing to do would be to contact the manufacturer.
Who installed the heating/floor ?
if it was a company then they should foot the bill of sorting the problem out.
The Heating Doctor
by The Heating Doctor » Thu Oct 25, 2007 8:07 pm
Contact the company who supplied/manufactured the underfloor system to find out if they do a room temperature sensor that can be wired in to the system. If not a room thermostat could be fitted to interupt the electrical supply to the matt. DO NOT FIT A STANDARD ROOM THERMOSTAT CONSULT AN ELECTRICIAN TO CALCULATE THE SWITCH RATE (IN AMPS) REQUIRED TO SWITCH THE POWER OFF AND ON. The current you are switching may be a inductive current & not a resistive current which means the contact rating of the thermostat will have to be increased to suit. You will also have to fit the type of thermostat that has a remote sensor to it as you can not put a standard room thermostat in a bathroom.
