DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Volex 10A 2G 2W Sw Blk Ins SS Round Edge DIY Doctor: Screwfix: Hand Tight Flexible Hose 15mm x 3/4 BSP 300mm Pack of 2 DIY Doctor: Screwfix: Speedy Hanger 75mm Long Leg Pack of 10 DIY Doctor: Screwfix: Screw Cover Caps Beige 8 Gauge Pack of 100
Share and bookmark DIY Doctor
what is the best satellite cable to install
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema
Author Message
arches
PostPosted: Tue Apr 29, 2008 8:06 am    Post subject: what is the best satellite cable to install Reply with quote
I am changing to sky HD and am going to route the cable myself ready for the engineer to complete the installation. Which cable will provide the optimum signal and reception.
Back to top
rosebery
PostPosted: Tue Apr 29, 2008 5:35 pm    Post subject: Reply with quote
Use a low loss coax, keep the cable run as short as possible and just have 2 connectors - 1 each end.
Poor picture can be as much to do with the cable as the signal getting into the dish I'd be tempted to let them suply and fit eveything. That way the finger only points one way when there is a poblem.
Alternatively if what you are doing is just pulling cables rather than making connections I'd ask the installer to specify the cable you should use.
Back to top
Guest
PostPosted: Sat May 03, 2008 7:52 pm    Post subject: Reply with quote
RG-59 is often used and RG-6 is also a 75 ohm cable with a little better properties but there are many 75 ohm cables many with no published loss and only safe way is to ask the installer they all call them selves low loss but some loose less than others. Remember the cable carries power as well as RF and this could affect the cable used.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
