DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Round End Sockets Brushed Nickel 25mm Pack of 8 DIY Doctor: Screwfix: Yorkshire Solder Ring Male Coupler YP3 15mm x DIY Doctor: Screwfix: Bosch Multiconstruction TC Pilot Drill DIY Doctor: Screwfix: Flexi Waste Straight Coupling 38-45mm
Share and bookmark DIY Doctor
Compatibility on Mini Disk Players
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema
Author Message
Guest
PostPosted: Thu Aug 14, 2008 11:08 am    Post subject: Compatibility on Mini Disk Players Reply with quote
I have a selection on Mini Disk players but only one a Sony MZ-RH910 will use Hi format as well as MD format and connect to PC. We have over time had a few Mini Disk players that would not work and have been considered as faulty but just got a large JVC mini disk player complete with a selection of pre-recorded mini disks and found it would not play mini disks recorded on the Sony MZ-RH910 in MD format although it showed what song should be playing and the same was then found with a Sharp MD-MT20 no audio although it shows song names the disks all work in the Sony MZ-RH910 and it is not Hi-MD format but Net-MD format recorded with Sonic Stage in another Sony player they all work OK. A third player a Sony MZ-N710 will also play all mini disks. Is there something special about Sony mini disk players which stops any other make playing disks make with Sony mini disk recorders. The Sony MZ-N710 will also record from the PC and again disks made with that unit only seem to play on Sony players? The JVC player was got with whole idea of playing mini disks and if it is faulty then we have good cause to return it but if it’s a Sony thing then not really fair to return it as not really a fault as such.
Has anyone else had similar experiences with mini disk recorder / players please.
Eric
Back to top
Guest
PostPosted: Wed Aug 20, 2008 7:07 pm    Post subject: Reply with quote
Found the problem there are 3 formats MDLP, NetMD and Hi-MD not two as I thought. Also there are 4 recording formats ATRAC, ATRAC3, ATRAC3plus and Linear PCM. In SonicStage in Tools, Options, Transfer one can select Net MD and transfer settings here there are three modes available Standard transfer mode, Specified bit rate transfer mode and SP transfer mode and a note that the latter is used for compatibility with non-MDLP MD devices and that it takes longer to transfer.
Easy when you know how!!!!
Eric
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
