DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Saniflo Macerator 550W/ 240V DIY Doctor: Screwfix: BAHCO Superior Hard Point Handsaw 7Tpi 22 DIY Doctor: Screwfix: Forge Steel Plastering Trowel 13" x 5" (330x127mm) DIY Doctor: Screwfix: Merlyn Frameless Chrome Eff. & Clear 800mm Side Panel for Shower Enclosure
Share and bookmark DIY Doctor
Arris rails - How do you make the holes in the posts?
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fencing
Author Message
Biscuitman
PostPosted: Wed Apr 09, 2008 2:24 pm    Post subject: Arris rails - How do you make the holes in the posts? Reply with quote
Probably a stupid question but how do you make the holes in the posts. Or do you buy posts with these ready done?
Before I start with my chisel and a heavy heart, has anyone got any tips or hints?
Just looking to do a small run of closeboard fencing on a slope (hence not fence panels - don't like the stepping)
Biscuitman
Back to top
bones
PostPosted: Wed Apr 09, 2008 2:59 pm    Post subject: Reply with quote
do you need to make holes in the posts?
Why not run your rails along the front of the posts, attaching with nails and then attach the boards to the rails.......no need for holes in posts.....or am i missing the question you're actually asking?!?!? :lol:
Back to top
ALDA
PostPosted: Wed Apr 09, 2008 8:17 pm    Post subject: Reply with quote
B,
YOU MENTION ARRIS RAILS IN YOUR POST.
THESE ARE APPLIED FLAT FACE TO BACK OF CLOSE BOARDS TO CREATE A PANEL.
YOU ONLY NEED TO USE RAILS/SPARS NAILED TO POSTS THEN BOARDS NAILED TO RAILS/SPARS AS "BONES" HAS PREVIOUSLY SUGGESTED.
TO CHISSEL OUT TRIANGULAR HOLES IN POSTS WOULD BE TORTURE, I'M SURE YOU'LL AGREE.
YOU COULD SAW "V" NOTCHES IN FACE OF POSTS TO ACCEPT ARRIS RAILS IF YOU INSIST ON USING THEM (MAYBE YOU HAVE ALREADY AQUIRED THEM , SO USE IS A MUST).
TAKE IT EASY,
ALDA.
Back to top
Biscuitman
PostPosted: Wed Apr 09, 2008 9:11 pm    Post subject: Reply with quote
Found elsewhere suggestion that you drill 3 overlapping holes with a 20mm drill bit and then clean up with a chisel - sounds a bit more feasible.
Back to top
mvkpe
PostPosted: Fri Jun 13, 2008 8:53 am    Post subject: Reply with quote
I would suggest using chamfered rails (or square)and surface mounting them to the posts, of course you will have to set the posts back from the boundry so that the o/s face of the featheredge is on the boundry.
Alternativly if you have to use triangular arris rails ether cut a flat on rails where they meet the posts and attach as above, or attach using screws or nails driven in at 45 degrees through the end of the rails (scew nailed) or use a "feine" or "bosch" oscilating plunge cutter to cut the holes or resort to drill and stitch method as mentioned in a previous reply.
The "saw a triangular hole" in the face of the post will effectivly half the strength of the post. :(
Back to top
charlief
PostPosted: Sun May 10, 2009 4:35 pm    Post subject: Arris Rails Reply with quote
You can buy galvanised triangular arris rail brackets so that you do not need to cut hole for the rails.Fit the uprights and 2 arris rails between and then nail the brackets to each end of arris rail and nail into upright.
Back to top
bd3cc
PostPosted: Sun May 10, 2009 11:50 pm    Post subject: Reply with quote
If it is definiely Arris rail(triangular) you use a galvanised connector to fix the rail to the post. Readily available from your fencing supplier
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fencing All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
